Author Topic: Oscilloscope - Leader LBO 513A Half Screen  (Read 843 times)
Offline KolvirTopic starter
« on: February 08, 2020, 06:38:53 pm »
I was given the scope, but it suffered so damage in shipping. The CRT only shows on the left side. The photo is supposed to be a square wave from the test terminal. Does anyone have suggestions of where I should start looking to fix this? I have the service manual. This is my first scope, so I don't know where to start. It worked fine before shipping.
« Last Edit: February 09, 2020, 09:04:05 am by Kolvir »
Offline torquil
  • Country: no
Re: Oscilloscope - Leader LBO 513A Half Screen
« Reply #1 on: February 09, 2020, 07:24:01 am »
Does it have wires going to horizontal deflection plates in the CRT? And if so, is one of them loose?
« Reply #2 on: February 11, 2020, 12:10:11 am »
I'm not sure, I am trying to tack it down, but haven't been able to find that exactly. I've checked all of the wires coming out of the CRT and they appear connected correctly. I think the unit took a blow to the side during shipping and am afraid there might be a broken solder joint or trace. Someone told me to get out the magnifying glass, but I don't have a lot of experience at this and am not sure I will spot the break.
Offline David Hess
  • DavidH
« Reply #3 on: February 12, 2020, 11:25:33 pm »
My first guess would also be that one of the horizontal deflection leads fell off.
Are the horizontal and vertical calibration correct?
Offline madao
« Reply #4 on: February 15, 2020, 05:12:50 am »
a dumb ask: did you turn horz position pots?
