These were quite unique machines. The dual mode card supported CGA for compatibility reasons and could output color to an external monitor but the built in display was monochrome. I would start by carefully inspecting the cable to the internal monitor and if that looks ok you might have a cracked solder joint in the monitor itself. If you have an external CGA monitor to try see if that exhibits the loss of sync, or you could put a scope on the sync signals.
I had one of these once, complete with a nice padded carry bag. Sometimes I wish I'd kept it.
