Author Topic: LCD Panel Failure  (Read 2036 times)
Offline VotalityTopic starter
LCD Panel Failure
« on: December 14, 2017, 11:59:26 am »
Just out or interest what would have caused this fault?
Looks like a fault with the LCD itself?? Not the electronics
Sent from my iPad using Tapatalk
Offline Armadillo
Re: LCD Panel Failure
« Reply #1 on: December 14, 2017, 01:17:52 pm »
Polarized front glass is cracked. :-(
Offline Mr. Scram
  • Display aficionado
« Reply #2 on: December 14, 2017, 01:19:00 pm »
It maybe looks like heat damage?
« Reply #3 on: December 14, 2017, 01:23:47 pm »
No crack at all.. heat do you think??
Offline Mr. Scram
« Reply #4 on: December 14, 2017, 01:29:57 pm »
It could still be a crack, but on the inner layers. If you put a lot of blunt pressure on a monitor it could happen.
« Last Edit: December 14, 2017, 01:59:18 pm by Mr. Scram »
Offline Armadillo
« Reply #5 on: December 14, 2017, 01:58:35 pm »
from the inside..... though the outside may be smooth to the feel.
Offline Koray
  • Country: tr
« Reply #6 on: December 14, 2017, 09:33:34 pm »
Could be humidity or some sort of oil ingress into the diffuser layers? K.
Offline james_s
« Reply #7 on: December 14, 2017, 09:36:37 pm »
That's unlike any failure I've ever seen before. It looks like maybe the layers are delaminating somehow. Certainly does *look* like the panel itself although that's no absolute guarantee. You could unplug the panel from the driver board and see if it goes entirely white.
