Please check the link and see the Recommended and Alternative model columns for each function.
For instance, I see 2 x E9304A Option H18 mentioned for CXA adjustment and performance testing, and if you don't have those my guess is that you will have a problem. Note that it's just a guess and not a fact, but you see where I'm going. If this is a one-off I'd personally find a company that can do it for you, less headache and probably a lot cheaper.
