Hello,
I am new here, I use to repair some audio stuff.
Many thanks to the creator of this forum, it's very helpful !
And I have a problem with my scope i bout in February, a Hantek DSO8060
I got it in Banggood quite cheap but I don't recommend this site for buying: it took about 2 month to arrive and i have a problem with it.
Suddenly Cannel 2 stop working. Not even the line was appearing on the screen. So, I changed one of the IC in the input and the green line appears but CH2 still does not work.
After measuring Ω and volts I suppose it's one of the relay (I suppose it's a relay) in the CH2 input. But no way to find the data sheet of it. It's written: PL-4.5nd I think it's a relay but it has 10 pins ... I'll try to upload a picture. No way to find any spare part for it.
Any help would be welcome. I am used to repair vacuum stuff, much bigger then the SMD components ...
[/img][/img]
