I've been handed a hot wire type anemometer to try to repair.
As expected the hot wire sensor is broken... This model was a thin glass tube supporting parallel running wires up to the tungsten heated tip.
Any clues to where I could find anything similar? I am aware that it will need readjusting if I can find anything.
