My Keysight U1272A started behaving strangely.
All DC voltage measurements have an offset error of about 1.6 V (this happens in “normal”, i.e. non-relative mode). When no voltage is applied (or when the leads are shorted), it displays about 1.6 V. When attempting to measure any voltage (say, a 1.5V battery), it displays that voltage + the offset error (3.1 V, in this case). The offset error can be compensated in “Null” (relative) mode. All the other modes (DC mV, AC V, DC mA, AC mA, R etc.) seem to work fine.
Resetting all the settings didn’t help.
I tried to store a different reference value (by pressing “Null” while applying an arbitrary voltage). The Null mode still seems to work as it should (it subtracts the new reference from the measured value), but the offset error in “Normal” V DC measurements changed as well (now is about 5.3 V).
Has anybody encountered a similar issue??
