Author Topic: Keysight MSO7034B, Teardown and Repair [Success]  (Read 17665 times)
Online nctnico
Re: Keysight MSO7034B, Teardown and Repair [Success]
« Reply #50 on: June 22, 2016, 04:26:07 pm »
Hmm, normally replacement capacitors are smaller, not bigger!
Offline Samogon
« Reply #51 on: June 25, 2016, 11:28:30 am »
This new cap has an ESR of 0.07 Ohm
But only measures 298 uF
May be this one is better, because it has a larger volume.
But who knows, I have never used a Vishay electrolytic capacitor before.
Thank you all for help and suggestions, it is really appreciated.
It is still in 20% tolerance.
Again nice deal you made with this scope. Congratulations!
Online Greybeard
Re: Keysight MSO7034B, Identify this diode?
« Reply #52 on: November 13, 2020, 12:43:14 am »
Can somebody help me to identify this diode in the front end of 7034A?
The font ends of 6034A and 5034A seem to be nearly identical to 7034A.
« Last Edit: November 15, 2020, 11:06:21 am by Greybeard »
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #53 on: November 13, 2020, 09:52:10 am »
Is the font end of 7034A identical to 6034A and 5034A?
Unlikely to be anything exotic  - just measure the one in another channel  to determine how many diodes, shottky or not, zener or not.
Day Job: Mostly LEDs
Online Greybeard
« Reply #54 on: November 13, 2020, 10:52:18 am »
I don't like the idea of unsoldering one of the working ones, that would be the last resort.
« Reply #55 on: November 13, 2020, 12:36:41 pm »
At least you could try measuring it in-circuit
Offline HighVoltageTopic starter
« Reply #56 on: November 13, 2020, 01:25:26 pm »
I still have the original high resolution pictures and cropped this area out again
But it is still not readable.
I suggest like Mike said, try to measure the part in circuit and compare it to the other channels.
« Last Edit: November 13, 2020, 01:27:15 pm by HighVoltage »
The following users thanked this post: Greybeard
« Reply #57 on: November 13, 2020, 06:00:53 pm »
Would also be worth looking to see if there are parts with the same marking elsewhere ( apart from other channels) - if there are this would indicate that it's probably a fairly general-purpose device rather than something exotic
Online Greybeard
« Reply #58 on: November 13, 2020, 08:20:14 pm »
HV: I tried to process your photos, but no success.
Mike: BTW, awsome homepage (tesla photos).
Online Greybeard
Re: Keysight MSO7034B - circuitry front end ?
« Reply #59 on: November 13, 2020, 09:42:00 pm »
Found a promising photo of the 1GHz frontend in this thread:
https://www.eevblog.com/forum/repair/agilent-dso6054a-noise-on-two-channels/msg853423/#msg853423
I think it is very probable same circuitry regarding this part:
So CR202/302/402/502 should be a double PIN diode HSMP3892 (HP/Agilent/Broadcom, marking code G2) = LXP1008‐23‐2 (Microsemi drop in equivilent).
https://www.digchip.com/datasheets/download_datasheet.php?id=384631&part-number=HSMP-3892
https://www.microsemi.com/document-portal/doc_download/9457-lxp1000-sot23-series-datasheet
PS:
Confirmed at 300MHz scope: Marking G25
Confirmed at 500MHz scope: Marking G2F
5 or F may be a maker or index mark.
PPS:
Case seems to be SOT-232 (smaller than SOT-23):
So correct diode type should be HSMP389C (same G2 SMD code):
« Last Edit: November 15, 2020, 11:43:19 am by Greybeard »
