Author Topic: Voltcraft LSP 1363 Power Supply - no Output  (Read 3069 times)
Offline ULYTopic starter
« on: June 03, 2016, 01:09:05 pm »
Hi there,
I have a broken Power Supply named
Voltcraft LSP 1363
it seems to be a clone of the
Manson NSP 3630
It powers up, I can set a Voltage and Current, but the output stays 0V and it displays 0V
- No Visual damages
- checked Transforators
Does anyone has a Service Manual or any Hint, where to start?
Offline dundee
Re: Voltcraft LSP 1363 Power Supply - no Output
« Reply #1 on: June 03, 2016, 10:32:10 pm »
This should be the schematic for the device:
http://www.produktinfo.conrad.com/datenblaetter/500000-524999/515266-sp-01-en-VOLTCRAFT_LSP_1363_LABOR_NETZGERAET_100W.pdf
D10A or D10B bad? Also check the mosfets.
The following users thanked this post: oz2cpu
Offline Strada916
« Reply #2 on: June 04, 2016, 12:29:28 am »
check the following are working U1, q2, q3, q7, q8, q10 & q11
I would check all the supply voltages first to ensure no voltages are missing. I would then start with q10 & q11 and go back
« Last Edit: June 04, 2016, 12:31:43 am by Strada916 »
The Bone, the Off-White, the Ivory or the Beige?
Offline dam234
« Reply #3 on: October 13, 2020, 01:05:14 pm »
Does anyone have the PIC18F87K90 MCU firmware for the VOLTCRAFT LSP-1363 power supply.
MCU is unlocked so you can read.
Online coromonadalix
« Reply #4 on: October 13, 2020, 02:21:33 pm »
link doesnt open  or it download an empty pdf ??
okay  got it, you have to search  LSP 1363
Yep   would be nice to have the pic dump
« Last Edit: October 13, 2020, 05:11:46 pm by coromonadalix »
« Reply #5 on: October 13, 2020, 05:08:48 pm »
@ ULY    do you enable the output with the button on the front panel ?? you have the output  on/off button
