So the long story short, i have an NVR that has an 8 port POE for 8 cameras. All of a sudden yesterday all cameras stopped working. After my investigation i have come to the conclusion that the NVR is not able to deliver POE anymore on any of the 8 channels. All other functionalities of the nvr is working fine, even the port still has its ethernet capabilities. I tested it by using a POE injector and the camera powered up and the NVR was able to see the camera. I only have 1 POE injector though and have 8 cameras. I could buy a new NVR but i would like to try to attempt to fix it first before getting a new one.
I have very little knowledge of how POE works so i need your help. Having only a digital multi meter makes it hard since from what i have researched there is some sort of handshake that needs to happen first before power is delivered. This is what im trying to figure out if its a component failure or a handshake failure.
Upon inspecting the board there seems to be no visible burnt component.
There is nothing much on the other side exempt the magnetics for the ethernet, The bottom side is where i think poe is delivered, there is a trace going to the left from the rj45 pins, which appears to be diodes, for tvs or rectification i do not know what i have found out is schematic kinda looks like this
The port seems to be in pairs, i plugged an ethernet cable and measured each pin voltage to gnd
PIN | Color | Reading
1 S-Green ??
2 Green ??
3 S-Orange +48v
4 Blue +48v
5 S-Blue +48v
6 Orange +48v
7 S-Brown ??
8 Brown ??
I also read the voltage of the port with a camera attached,
- Portx_PIN_A to GND = +47.3V
- Portx_PIN_B to GND = +48.0V
So power is really delivered to the camera. Anyone know what might be happening?
