Author Topic: Fluke overmoulding has peeled off  (Read 649 times)
Offline razirafiTopic starter
« on: April 22, 2023, 08:09:20 am »
Hi to all, I have a Fluke 179 that has served me well for about ten years since purchasing it.  Recently the overmoulding on the bottom half of the case has peeled off.  May I know if others have experienced this and if this can be reattached?  I tried using cyanoacrylate but it did not hold up.  I also tried using Permatex Clear Adhesive Sealant 80050 but it still failed.  I am also wondering if this is covered by the Lifetime Warranty of this product.  I have seen on Ebay an original bottom case for this model but the price is quite expensive.  Any thoughts on this?
Online Psi
Re: Fluke overmoulding has peeled off
« Reply #1 on: April 22, 2023, 08:14:24 am »
You could email fluke and ask if they can do anything, they are a pretty nice company.
« Reply #2 on: April 22, 2023, 08:45:04 am »
Hello Psi, thank you for your reply.  I will try that and see if they will be abe to help me out.  I just needed to know if someone else has experienced this and was able to find a way to reattach the peeled off section with success, and what adhesive was used.
Offline minifloat
  • loss of precision
« Reply #3 on: April 23, 2023, 09:24:55 pm »
If you know someone able to 3D-print elastic materials, TPE or TPU, this might be a way to go.
Otherwise, search online auction platforms for defect multimeters of the type you have, buy it, use  the rubber and the rest goes into electronics recycling.
br, mf
