Got a 576 that was supposed to be in working order but it seems it is no even close. After rebuilding the collector supply, I managed to get sweep again on the tube but the tube is VERY dim The picture shows the tube with the intensity turned all the way up. I have a strong high voltage power supply and it is exactly where it should be. given how faded the graticule lines are I have a suspicion the former owner stored it in the sun and it baked the tube. Is there any way I can safely drive the tube a little harder to try and get some brightness back. I also probed the 225V intensify pulse and it seemed it was stuck high it was not pulsing like it should. Any way to bring this on back or do I have a parts unit? The odd thing is the tube is uniformly dim it is but burned just not bright.
