Are you a candidate for Darwin awards? ![Laughing :-DD](https://www.eevblog.com/forum/Smileys/default/smiley_laughing.gif)
Trying to repair a cheap, poor quality, crap power supply without a schematic by making a dangerous repair attempt, you are a good candidate .... ![Laughing :-DD](https://www.eevblog.com/forum/Smileys/default/smiley_laughing.gif)
Do you own at least a good isolation transformer? ![Banging Head |O](https://www.eevblog.com/forum/Smileys/default/bangheadonwall.gif)
No need for the insult thanks. I have already acknowledged the risks associated with looking at it.
It wasn't a cheap eBay or the like purchase and the case is labelled with a well known (in the hobby) brand.
The fuse is the one that came with it but I've only typically drawn about 4 amps from it.
I don't particularly need it as I have been using my DP832 instead.
However, as I said, (if someone recognises the board) if there was anything obvious that it could be, I could consider swapping out the part, just for the pleasure of not throwing it in the bin.
If you consider a simple joke as an insult, it's not my fault ....
But there are truths behind this joke:
1) To troubleshoot a SMPS, it is often necessary to turn it on and make measurements.
The voltage on the primary side is 320 Vdc with an unlimited current far exceeding 30 mA.
This can be lethal.
In the event of an error or wrong operation, you risk not only damaging your oscilloscope, but also electrocuting yourself.
2) It seems that you do not have much experience with SMPS, the proof is that almost all the participants of this topic have noticed that it was a product of low quality and technology and you do not .
As Dave would probably say if he were to review such a power supply: bullshit.
3) to work efficiently and safely, it is better to know exactly where one connects his oscilloscope .... It is, in my opinion, essential to have a diagram.
The first thing someone who would have experience would have done is to do some reverse engineering and draw a "DaveCad" schematic at the very least of the primary circuit.
You did not do it, which shows no professionalism on your part.
So, yes, if you happen to have a serious accident repairing a dangerous smps, poorly made while it is not worth it, you deserve a Darwin Award .... maybe not in the top 15,
