I was thinking of using my old Dremel as PWM controller for 775 motor.
The thing powers up but there are two wires white and green that senses cell voltage for LVC that had 18650 cells and am not sure how to bypass it since the power source is no more a cell. The pcb has this MUC
and the pcb
![](https://uploads.tapatalk-cdn.com/20170829/1404d8a2fe58e55d0c800b0c6a22aabb.jpg)
Another pcb that used to be connected to the 18650 cells.
![](https://uploads.tapatalk-cdn.com/20170829/3406d3a57ca5275fdc7c7ff2d4a4ca09.jpg)
On checking the MUC i found this from TI
http://www.ti.com/lit/ds/slas491i/slas491i.pdfI would appreciate if somebody could help me by pass the LVC.
