I'm not going to look through the manual, but I can offer some suggestions based on hundreds of Sony monitors I serviced.
You are sure it is set to the right standard? NTSC PAL Secam?
Obviously not in "blue only" mode....
And finally, before going nuts, I have seen this in PVM's many times, check the color oscillator trim capacitor. I have had this issue MANY times, but mostly in the small 80 series PVM's. A tiny nudge of the color oscillator trimmer would pop it right back in.
And... the "L" series does suffer from leaking capacitors..... yep...
Hope that helps before you dig in deep.
