Author Topic: Philips 55pus6162/12 repair?  (Read 514 times)
Offline JekgbgTopic starter
« on: July 13, 2024, 11:43:04 am »
 Hello
 Have the TV (philips 55pus6162/12) switched on, after about 1 hour a bang was heard and the display went black, only the on/off led light was on, disconnected all cables and tried to start again but the same result, black display and led light  on.
 What could be wrong?
Re: Philips 55pus6162/12 repair?
« Reply #1 on: July 13, 2024, 11:50:11 am »
Found broken condenser.
 Found broken ceramic capacitor C8113 100pf on
 Powerboard, can you continue troubleshooting without voltage with diode measurement?
 Power board
 TPV 715G8672-P01-000-002H
 Philips55pus6162/12
« Reply #3 on: July 13, 2024, 01:56:13 pm »
How do I measure these 2 black ones, are they transistors?  Closest to the cracked capacitor (blue)
« Reply #4 on: July 13, 2024, 08:43:55 pm »
how is one N-channel mosfet measured in diode mode?
Online wraper
  • Country: lv
« Reply #5 on: July 13, 2024, 08:59:33 pm »
^The only thing that should be measurable is the body diode between D-S. Otherwise it should measure open.
Offline DavidAlfa
« Reply #6 on: July 13, 2024, 10:23:53 pm »
Beign in-circuit is will measure some resistance, but fets usually fail short and explode.
Check if R8101 is alive, should measure short (0.1R).
« Last Edit: July 14, 2024, 05:59:13 pm by DavidAlfa »
« Reply #7 on: July 14, 2024, 05:29:06 pm »
got this result
Offline DavidAlfa
« Reply #8 on: July 14, 2024, 06:00:26 pm »
Measure resistance in each transistor, between legs 1-3, 1-2 and 2-3.
« Reply #9 on: Yesterday at 11:45:19 am »
Mosfet 1
1-3= 00.00 ohm
1-2= 00.00
2-3= 00.00
Mosfet 2
1-3= 00.00
1-2= 70.5 kohm
2-3= OL
Offline Harry_22
  • Country: hn
« Reply #10 on: Yesterday at 12:29:46 pm »
Hi!
Рarts marked yellow should be checked, red parts should be replaced.
Could you make a good photo from bottom side.
Offline DavidAlfa
« Reply #11 on: Yesterday at 01:05:18 pm »
Now remove the transistors and measure them out of the board. Probably dead.
« Last Edit: Yesterday at 03:46:57 pm by DavidAlfa »
« Reply #12 on: Yesterday at 03:54:44 pm »
Offline Harry_22
  • Country: hn
« Reply #13 on: Yesterday at 05:12:59 pm »
Check also Q9801 PFC MOSFET.
« Reply #14 on: Today at 09:15:27 am »
I didn't mention from the beginning that the main fuse was intact, maybe that says something about the damage.
