The invertor has 2 air fans that start only when quite a high electricity consumption is needed . Otherwise the fans are quiet. It worked that way for about 2 years. Now,however, the fans work all the time.
On the enclosed pictures you can see a region where fans are connected. It seems quite simple. Anyone knows the principle , how the fans are controlled?
Thank you
