Author Topic: Intron Instruments DSO-2000A Oscilloscope both channels tilted  (Read 1028 times)
Offline jakekooTopic starter
« on: January 30, 2020, 05:38:38 pm »
I got this oscilloscope in really good condition and about everything seems to work except both of the channels are tilted by the same degree. I find just about nothing about this Intron Instruments by googling. All the trimpots are marked only by some number and letter combinations. How should I proceed?
Oh, first post here. I'm electrician and know the hazards here.
« Last Edit: January 30, 2020, 05:57:47 pm by jakekoo »
Online TheDefpom
  • YouTuber Nerd - I Fix Stuff
    • The Defpom's Channel
Re: Intron Instruments DSO-2000A Oscilloscope both channels tilted
« Reply #1 on: January 31, 2020, 04:47:03 am »
Most likely the yoke has turned on the rear of the CRT.
Im no expert on CRT but have tinkered with them a little over the years, this is what it seems like to me.
Cheers Scott
Offline m3vuv
« Reply #2 on: January 31, 2020, 07:42:47 am »
has the crt come loose and rotated?
« Reply #3 on: January 31, 2020, 09:05:48 am »
There was trace rotation potentiometer on the back panel which solved the problem.  :phew:
This potentiometer is rare on oscilloscopes from this era but this being kind of digital makes it possible.
Online tggzzz
« Reply #4 on: January 31, 2020, 01:34:04 pm »
No, and no. They were common and are nothing to do with it being digitising.
The following users thanked this post: shakalnokturn
Offline shakalnokturn
« Reply #5 on: February 02, 2020, 01:28:51 am »
There is no "yoke" on this type of CRT.
At least in the era of round CRT's you could do a physical trace-rotate  ;D
« Last Edit: February 02, 2020, 01:30:26 am by shakalnokturn »
