seems to fit attached image not sure it's the good one
green black and brown red
who would be 5 ..... exponents / divider / multiplier .... should be 50 divided by (10 exp 1) 100, will give your 0.5 amp, and the red color give a 2% tolerance ??
you have to find the charts on the web
not to be confused with the resistor color codes, because the multipliers bands etc ...
