Author Topic: Industrial proximity sensors. Magnetic or inductive?  (Read 1618 times)
Offline oliver602Topic starter
« on: June 09, 2021, 01:00:41 am »
Hi
I need to replace a M12 threaded cylindrical proximity sensor on some farm machinery.
There are two magnets spaced apart to trigger the sensor at different positions as a hydraulic cylinder is retracted or extended.
The output is normally open npn. And there is a fair amount of slop in the machinery so a reliable sensing distance of at least 5mm.
I thought this was a hall effect proximity sensor,  but when I searched the big distributors those types of sensors were for speed sensing.
I think a magnet sensor would be more selective considering the dirty environment. Is an inductive sensor ok for this application?
What kind of sensor should I search for?
« Last Edit: June 09, 2021, 06:41:10 pm by oliver602 »
Offline Renate
Re: Industrial proximity sensors. Magnetic or inductive?
« Reply #1 on: June 10, 2021, 11:40:10 am »
It sounds like this is a Hall effect sensor.
Whether you use this for a limit switch or a speed sensor is just your application.
Does this have a 3 wire connection including (probably) a +5V source?
Why do you need to replace them?
Multiple ones going bad sounds fishy.
Are you sure that you didn't lose your supply voltage?
« Reply #2 on: June 10, 2021, 12:02:53 pm »
It's a 3 wire sensor and the supply is 12V. It's a fairly old machine and the sensor is exposed to the weather so I'm assuming water ingress. But I don't know the history. The output was shorted to + supply.
Offline TheMG
« Reply #3 on: June 10, 2021, 01:21:17 pm »
The difference between the two types is that the inductive prox sensors will trigger on anything metallic, while the magnetic sensors will only trigger in the presence of a magnet.
Offline Renate
« Reply #4 on: June 10, 2021, 02:55:10 pm »
Hmm, that's a bit strange.
If it's a normal open collector output there's possibly none or minimal components between the collector and the +V supply.
Are you sure what it's feeding is not shorted? Or the wires?
« Reply #5 on: June 10, 2021, 04:52:41 pm »
Yep I checked the wires and electronics on the machine. The sensor output is connected to a 40106 schmitt trigger inverter through a diode. I also had the sensor off the machine hooked up to a power supply. I had blue and brown wires connected to the power supply and tried triggering the sensor with one of the magnets I took off the machine from both north and south pole and the voltage on the black wire was always 12V.  Then I measured the resistance between all the wires and found black shorted to brown.
Offline fordem
  • Country: gy
« Reply #6 on: June 10, 2021, 06:44:02 pm »
An inductive sensor senses disruption of it's magnetic field, whereas a magnetic sensor senses the presence of a magnetic field, so the first can only sense when the hydraulic cylinder moves into a given position, but not if it's already in that position.
If it's limit switch application, then a magnetic sensor is what's required, and what you're describing sounds like a hall effect sensor - you could also use something like a reed switch which would close when the magnet is nearby, and open when it's not, but that would be a two wire device, not three.
Offline mikerj
« Reply #7 on: June 10, 2021, 09:20:58 pm »
This isn't true, the inductive proximity sensors will detect static positions.  They are not variable reluctance sensors that only respond to moving targets.
The following users thanked this post: bck
Offline Renate
« Reply #8 on: June 10, 2021, 09:49:33 pm »
Well, it's definitely a Hall effect sensor.
... one of the magnets I took off the machine from both north and south pole ...
Are the two magnets on the machine showing the same polarity?
There is a strange beast of a latching Hall effect sensor that gets turned on by a south pole and turned off by a north pole.
If this hydraulic cylinder was supposed to only extend and retract fully this could be the (weird) case.
It's probably just a regular Hall effect sensor.
I presume there is a pullup on the input of that Schmitt trigger?
There's a lot of M12 sensors here: https://www.digikey.com/en/products/filter/magnetic-sensors-position-proximity-speed-modules/552
In a pinch you could even use a reed switch if it will get your machine back online.
