Hello,
I remove the below heatsink (at the attached image) where it had indium foil thermal pad. As I read on the internet indium foils don't have a very good thermal conductivity. Do you know if there is a specific reason for the using of indium foil? Can I use a thin thermal pad instead of indium foil?
