Hello,
I live in France and I came across this site and your message BU508A by chance.
But I'm already stuck before going to test the capacitors designated as probably "sick", because I don't see how to get the board out of the power supply.
Do you have a tutorial that explains the disassembly. I own the Visacustic 1000 but I think it should look like the 2000.
Thank you all for helping me.
Denis
Bonjour Denis,
sorry, the only document I own are the schematics which I've placed in the first posting.
Disassembling of those machines is really a pita and the only advice I can give you, is: take pictures. Lots of pictures. From different angles.
Good luck with your repair.
