In short, I believe that your backlight draws 28W, not 84W, and that the LED current is more like 120mA:
In the datasheet for my panel it is saying 350mA, in the datasheet you posted it states 125ma Can it be that apple wanted a brighter panel?
james_s:
I'll do some more testing this evening. The inverter is a used inverter I bought, it is a later version but still overheats the same. The temperature measured is when it was inside as the LCD temperature sensor would not reach outside the unit! So the fans seamingly do not help. I have already cleaned all the fans in this IMAC. I also put a fan on it from an old graphics card and that did barely anything but there is not room for the airflow behind the inverter with a small fan....
It cannot be normal as the back of the Imac is red hot where the inverter is. The only thing left is the LEDS if not the inverter!
I have ordered some LEDS for this panel for £16, since I cannot find the correct replacements individually and need to try to resolve this soon.
Both the inverters run at 95 to 98c!
I thought it should shut down as well and I also thought like you that they're either short or open, but all of them light! So I am totally confused! It does shut down when there are no LEDS plugged in!
