This is my first post in this forum so if there is anything wrong, let me know and hello!
I am trying to fix: A1312, iMac 27-Inch "Core i7" 3.4 (Mid-2011):
First off I have the Imac Schematic but only for the mainboard, does anyone have the inverter one or a similiar one from another for better understanding?
Searched all over for one!
All voltages to the Inverter are correct:
(12v in, 3.3v Enable and PWM Approx 3.0v).
Output was 12v and moved a little but Inverter was obviously cutting off as D1 was SHORTED.
After replacing this the IMAC works for 1 week exactly and dies again.
When working, the output was 36v @ full brightness and 28v minimum. Before repairing the Inverter I tested the LEDs one by one in the display with a multimeter in diode mode and they light up and had same diode reading so I thought there was no fault there. I also tested the strips when out of the display on the Inverter and all lit as normal!
I just confirmed the same Diode was Shorted. I had replaced with the exact type from RS electronics (V10P10), Datasheet attached.
There are 2 others on the board which are still fine.
There are 3 sets of Inductors that are sharing the load but why does this one always blow??
I have removed all three sets of inductors and the 3 switching MOSFETS 23N06-31 (Tested working, switch on and off when charging the gate with multimeter), all inductors show conductance but can they fail another way? Like windings shorting?
All the diodes have the same readings. All the capacitors tested ok I thought, the 2 input ones 420uF instead of 470uF, the output ones 41 instead of 47uF and on my ESR meter well within spec. I will replace them all now while waiting for replies.
So any ideas as to why it has blown 2 so far!
On the return of this IMAC I wired the board outside the unit and it gets very HOT!! Almost too hot to touch. It is hard to know exacltly what but appears the MOSFETS/INDUCTORS ! And the 0.24 ohm resistors which I'll label on the picture, I believe these are for current sensing.
If I turn the brightness below acceptable level the board goes cold, indicating too much current draw I think! But can LEDS be faulty and do this, I thought they blow open circuit and surly the whole point is the Inverter is Current Limiting!!
I have annotated the pictures please have a look.
Many thanks.
