I would replace all 6 Sucons ( appropriate name, SUSpect CONdenser) with new ones, and also replace the 2 small electrolytics on the primary side by the switching controller, they will be near to failure from being toasted by the hot parts near them, and will fail soon if not replaced. Resolder the 2 power diodes as well, they are rather well known to crack the solder joints by the rivets, so resoldering all those joints is a good idea, along with the joins on the power transformer and the mains connections as well.
