Author Topic: Repairing Battery Pack  (Read 2025 times)
Offline bagetTopic starter
« on: September 01, 2014, 07:36:11 pm »
Hello
I have a cheap battery pack that does not seem to work.
the PCB has USB connector for power output and microUSB connector to power input
when I connect a microUSB I always see a green light indicating that the battery is full...
when I measure the volt on the battery I get ~0.850v when I unplug the microUSB power I see the battery volt is downing down very fast...
the ICs on the PCB that I could see are:
DW01 and 8025A
I think the problem is with the battery, what is the best way to confirm that expect from replacing the battery?
Offline amyk
Re: Repairing Battery Pack
« Reply #1 on: September 02, 2014, 04:52:33 am »
DW01 and 8025A
That's a pretty standard lipo protection combination. If you measure 0.85V on the cell itself then it's certainly dead, if it's after the protection then check the voltage at the cell terminals to be sure (be careful of shorts!)
« Reply #2 on: September 02, 2014, 09:16:13 pm »
DW01 and 8025A
0.85v is on the battery terminals
Offline amyk
« Reply #3 on: September 04, 2014, 01:10:38 pm »
Dead cell.
