Author Topic: Identify a capacitor  (Read 3042 times)
Offline JaxmotoTopic starter
« on: August 30, 2014, 10:36:24 pm »
Weekend warrior, I'm not great with the terminology...  looks like what I call a vertical surface mount aluminium cap.
The markings are (in this order and shape):
54 (maybe 5  4)
220
6s (the s is underlined)
Here is a picture of one of the good caps that are next to it (I can read everything on the bad one so I know it is the same).
Also, I have a huge inventory of thru-hole regular caps, would it be ok to use one (with proper specs) in place to test the board?
Offline tautech
Re: Identify a capacitor
« Reply #1 on: August 30, 2014, 10:59:27 pm »
Electrolytic 220uF 6V.
Sure, anything similar will do for a quick check
« Reply #2 on: August 30, 2014, 11:06:15 pm »
Thanks.  Normally I'm pretty good at finding this stuff myself but I couldn't find any reference to a "6s" cap.
Offline mariush
« Reply #3 on: August 30, 2014, 11:37:48 pm »
It's not 6v ... or it's unlikely to be 6v.
The S may be a code representing the voltage rating (but the code varies from manufacturer to manufacturer), or the 4 in "5 4" may tell you the voltage (4V).  The numeric voltage ratings are somewhat standardized and the most common ones are 2.5v, 4v, 6.3v, 10v, 16v, 25v etc
Otherwise, I'm fairly sure it's a 220uF.. usually when there is enough room on the capacitor, the actual value is printed.  When the cap is very small, they often use the notation where the last digit is the number of zeroes .. for example 821 means 82x10 = 820uF
« Reply #4 on: August 31, 2014, 12:16:08 am »
I dropped on a 220uF 25v since there was room and it did not resolve the issue I was having.  It can't be much higher than that even if it isn't 6v.
It's on a DLP projector that starts the startup cycle but then goes to "warning" state and stays there.  There was an obviously bad cap so it was just a shot in the dark that it might get it going.
Offline 4thDoctorWhoFan
« Reply #5 on: August 31, 2014, 12:52:03 am »
I'm almost positive that the cap is a Panasonic and the 6 designates a 6.3V cap while the S is the actual series of caps.
Offline HighVoltage
« Reply #6 on: August 31, 2014, 01:14:18 pm »
I just bought a similar capacitor
This one has 25V, 820uF, 20% Tol.
On the capacitor it is printed
J1
820E
CM
May be only the capacitance can be read directly, the rest has to be found in a Datasheet
Offline caall99
« Reply #7 on: September 02, 2014, 06:55:47 pm »
Many companies remove the decimal place for 6.3V SMD caps (Nichicon says so on its SMD cap datasheets). Its definitely 6 volt 220 uf.
Calibration Equipment:
Calibrated Agilent 3458A, Datron 4000A, Datron 4708, EDC MV100G, EDC MV105
Other toys: HP 3457A, HP 3456A, HP 34401A, HP 33120A, Agilent E3642A, Agilent E3648A
