Author Topic: Id this chip  (Read 681 times)
Offline coromonadalixTopic starter
Id this chip
« on: December 06, 2019, 12:26:50 pm »
Its used in a can bus interface right after an sn65hvd251 / "vp251 markings" transceiver
Z07D  markings,  sot 363 casing
pin
1  from vp251
2  ground
3  out to an stm32
4  from vp251
5  vcc 3.3 volts
6  out to an stm32,  pulled to vcc 3.3 k thru 10k ohms
No direct connections or low ohms between in and outs,   not sure its an esd protection device ?
Searched on smd databases, nothing conclusive ?
thks
« Last Edit: December 06, 2019, 12:29:16 pm by coromonadalix »
Online nali
Re: Id this chip
« Reply #1 on: December 06, 2019, 12:59:39 pm »
The following users thanked this post: coromonadalix
Re: Id this chip
« Reply #2 on: December 06, 2019, 03:23:28 pm »
you da man  thks
Never tough of buffers ...  surprised to see this chip applied here,  unlees they use it to make a level shifter between the vp251 (5vdc supply) and the stm32 at 3.3 volts ??
« Last Edit: December 06, 2019, 07:32:56 pm by coromonadalix »
