I would try an 2n3055, they are easily found, you have 2N3772, 2N5686, 2N6338, 2N6339, 2N6340, 2N6341 ... any TO-3 case NPN who has 20 amps collector current.
You have an 4 amp fuse in the line, it would help start the radio.
Do you have an beefy 13.8v 20 amps power supply around, fixed or variable current limited just in case
![Huh? ???](https://www.eevblog.com/forum/Smileys/default/huh.gif)
you could try to put an supply on p4 pin 1 (DCI) once p5 is removed.
Q2 is not necessarily broken, it is an powerful transistor, 100v at 30 amps, normally they wont go up easily, unless a thermal breakdown, badly dissipated heat ... killed it.
You have Q1 and Q3 to check, all the zenners, electrolytics ... low values ceramic or mica capacitors.
The 2 zenners in serial give 10.2 volts (5.1v each)
All this circuit to make an 13.8v regulator ... no current limitation.
