EEVBlog Repair Jedi(s):
The last fall I purchased a IC-271H at a local (Cincinnati) hamfest.
My goal with this rig is to explore weak signal VHF (find out if there are any QSOs to be had...)
Status:
- Rig has a IK2RND memory card installed, with a 05-2015 date
- 100% on FM (Tx works, Rx works - great signal reports)
- SSB Tx was intermittent and has since stopped working
- I have a complete copy of the ICOM service manual and schematics
- This project is a "step up" for me in terms of my repair skills - and that was part of goal in buying the radio (learning new maintenance / electronics skills)
- For test equipment, I have a 50Mhz O-scope, multi-meter, 20Mhz function generator, soldering stuff, and a Kenwood TH-F4 (that has SSB 2M Rx).
When I first set-up the rig, I was able to make 2 QSOs on SSB.
My goal is to repair the radio such that it works properly on all modes (SSB, CW and FM).
The style of construction of this radio has me a little intimidated - mostly the fact that there are so many (delicate looking) wire interconnects between sub-systems, and the fact the ICOM really packed all of the components very tightly in the design.
So far I have:
1. Conducted a visual inspection of the radio internally (w/o removing any sub-assemblies).
2. Have located/identified the ICs and components that are described in section 5-2-1 "Audio Amplifier and Limiter Circuits)
(photos attached of those areas)
Everything looks OK - at least I don't see anything that looks burnt, poped, leaking, etc.
Note quite sure what my next steps are and I'm looking for some coaching.
Also, I am not quite sure what safety steps I need to take while working on a radio like this. The primary step I have taken so far, is using a 5A limited lab supply to power it while it is on the bench. ( I have access to a 30A supply also, but can't current limit that supply.)
Any ideas?
Thanks,
Erik / AC8VK
