I've got a used HT79 clamp meter here.
Some simple dc current measurement tests show values about 10-20% too low.
When I press the "ZERO" button in dc current mode the meter tries to zero but after some seconds the "mA" in the display disappears and pressing the "ZERO" button again nothing happens anymore. The meter seems to be stuck and only gets reset out of this when it is powered off and on again.
If there is some kind of service instructions available or somebody out there who knows what's going on with the device it would be very helpful. The pcb has a bunch of trimmer pots on the back, but I doubt that only adjusting the correct one solves the problem.
