Author Topic: HP8566B Display fault  (Read 1121 times)
Offline TSLTopic starter
« on: November 12, 2019, 10:35:19 am »
Hi all,
I've just turned on my 8566B to do some work and the display is all weird!
I don't know how to describe it so I took some video of what's happening, you can see that here...
https://photos.app.goo.gl/TjZjwrJvDpDh4DLU9
Has anyone seen this before ?
thanks
VK2XAX :: QF56if :: BMARC :: WIA :: AMSATVK
Offline 0culus
Re: HP8566B Display fault
« Reply #1 on: November 12, 2019, 10:55:10 pm »
I haven't seen this symptom before, but it *could* be something going bad in the digital circuits that drive the display. If I recall correctly, the stuff shown on the display is fully digitized, so corruption in the readouts, traces, and graticule could be related to that.
Offline pbarton
« Reply #2 on: November 12, 2019, 11:59:32 pm »
Strange, looks like its working correctly 60% of the time and its failing 40% of the time.
When its failing, it appears to me as if the X and the Y are collapsing, the same amount, at exactly the same time.
No problem with the Z axis or the CRT high voltage.
The X and Y, display D/A converters probably have a common Reference Voltage?
If this common D/A converter Reference Voltage is collapsing (40% of the time), then you could end up with your symptoms?
Offline 0culus
« Reply #3 on: November 13, 2019, 12:03:42 am »
Could be bad caps too. I have one IF/display in service with a 66A RF section that has a barely perceptible wobble that goes away after warming up. This might be an early symptom of what yours is doing.
Offline tkamiya
« Reply #4 on: November 14, 2019, 11:56:14 pm »
Looks like it had too much to drink.....
« Reply #5 on: November 15, 2019, 12:42:01 am »
It does look drunk doesn't it!
I've had some interesting responses on the HP-Agilent-Keysight list pointing me towards C2 on the PSU for the display unit on board A1A10.
And there are a few other nominated PSU caps to go take a look at.
Hopefully I'll get to look at it this weekend once I extract the SA from the mountain of gear sitting on top of it.
I'll report back with detail and pics once I find the fault.
regards
Offline tkamiya
« Reply #6 on: November 15, 2019, 01:25:57 am »
I think the grid, waveform, and annotations are all generated separately.  So at least one of them something reeeeeeally good to drink.  Rest of them had tea.
I have some spare parts for the display unit.  If you run into situations you need proprietary parts, let me know.  I'll see if I can dig that out and send it to  you.
« Reply #7 on: November 23, 2019, 09:04:16 am »
Hi All,
I've fixed the 8566B display issue :)
Thanks to a chap on the HP Agilent list for pointing me at C2 on the A1A10 board. That was the culprit.
You can see it on my cap tester here...
With an ESR of 11K and its new capacitance of 17nF I'd say it is quite buggered!
I took the opportunity to check other caps around the box and they are OK :)
cheers
