Yes, there is a problem with the vertical amplifier. First image below tells how beam finder works.
For now, set Chan B on, Chan A off
Set 20 Volts/Div, input Gnd
Set POSN UP
Second image shows where to measure across path through vertical amplifier, from delay line to deflection plates. All points should be close to zero Volts. Somewhere there will be a big difference. This pushes beam off top of screen. Beam Find reduces the difference (gain).
