Hi, guys,
Could anyone have any ideas to help me with troubleshooting?
Me and my wife have Kronaby watches. These are bluetooth. We like them, as no need to charge, the battery should last for two years. Mine is running already for more then a year, no problems. But my wife’s watch, when it came, the battery was flat dead. I thought, its just battery. Replaced it. Two months later, her Kronaby app in phone informs, that battery is almost depleted. Hmmm... Something wrong. The watch works fine, but the power drain is excessive. The reseller would not accept it back, saying I already opened the cover to replace the battery. (You know, they do not like customers, they like their money.)
So, I disassembled it, to compare the current draw with that of my unit. Checked for shorts, with a thermal camera and with multimeter, checked the caps, etc. No problems. Then compared the current draw. Measured it with a scope across a 10 Ohm resistor wired in series. Here is the picture of voltage drop in my watch:
Now my wife’s watch. There is a constant voltage drop on the resistor of around 7.6mV. You can see the cursors showing it:
So, differently from my watch, my wife’s watch is constantly drawing about 760 uA of current.
I looked the datasheet for the Bluetooth module used in it. (Have not disassembled my watch to access the module, but it may be different as the movement of my watch is different from that of my wife). It says in the datasheet that the 16MHz crystal should draw only around 25 uA in standby:
Where do you think I should look for problem? Could it be that this T160 crystal is sucking current constantly? Any ideas? Here is the photo of internals:
Thanks a lot.
