Thanks for the help that worked.
On the pcb there is some capacitors in short circuit (C4, c5, c7, c8) and also the battery pads make continuity
On U1 the two pins on the bottom left have continuity with each other and with the top middle pin could this be a broken voltage regulator that caused this
Btw the issue was caused by overvolting
