Author Topic: Need help identifying 5mm pitch forklift PCB connector  (Read 773 times)
Offline FF_CCSa1FTopic starter
« on: June 08, 2023, 06:47:42 pm »
This is a long shot, but Google as well as endless inventory browsing has failed me. I'm repairing a PCB for a Merlo branded forklift-loader-thing, and one of these connectors is burned out. Does anyone have a clue what they are? You can see the logos from two different brands in the microscope image, but no amount of reverse image searching has brought me any relevant hits.
The pin pitch is 5 mm and the pin diameter is about 1 mm.
If anyone has any clues about what these are, I'd appreciate that a lot.
Thanks!
Online langwadt
Re: Need help identifying 5mm pitch forklift PCB connector
« Reply #1 on: June 08, 2023, 07:52:05 pm »
metrimate?
The following users thanked this post: FF_CCSa1F
Offline Jon_S
« Reply #2 on: June 09, 2023, 10:50:12 am »
It looks exactly like a Trident TST-range connector, but I don't think I have ever seen a 15-way before and the current catalogue don't show it as an option. Possibly a 'compatible' off-brand?
Trident Catalog
« Reply #3 on: June 09, 2023, 04:11:47 pm »
This is definitely on the right track (as are Metrimate, thanks langwadt!)!
The 24 pin and 12 pin TST connectors seem to be compatible with the connectors on the board, even though it's a different brand. So these will actually work if I can track them down! Thank you so much! The specific numbers for these are ITT CANNON TST12RB06T and TST24RB06T.
Sadly, these connectors seem to be difficult to get your hands on, so if anyone has any clues about what those "compatible off-brands" might be, do chime in. But I can probably figure something out based on this. What a relief!!
EDIT: Alright, barring reputable retailers, I managed to find some on Ebay. Hopefully they'll pan out okay. Thanks again for the help!
« Last Edit: June 16, 2023, 09:50:16 am by FF_CCSa1F »
