Author Topic: HP Agilent 6050A Electronic Load Mainframe repair  (Read 1184 times)
Offline Jay_Diddy_BTopic starter
« on: September 11, 2021, 08:30:45 am »
I just bought an HP 6050A Electronic Load Mainframe that was described as:
For parts or not working
“Untested, No Warranty or Returns, Item As Is; Issue(s): Unit does not power on.”
You can look at the pictures on eBay. eBay item number:274833496729
Do you want to guess why the unit won't power up?
It will be a few weeks before I receive the unit.
Regards,
Jay_Diddy_B
Offline Jwalling
  • This is work?
Re: HP Agilent 6050A Electronic Load Mainframe repair
« Reply #1 on: September 11, 2021, 09:00:11 am »
They were using 120VAC?
Jay
System error. Strike any user to continue.
Offline ddrl46
« Reply #2 on: September 11, 2021, 10:03:44 am »
Probably the top cover not being screwed on all the way causing the interlock to remain open.
« Reply #3 on: September 20, 2021, 11:06:02 pm »
You are almost right. I am using 120VAC and the unit was configured for240VAC operation.
I don't know about the interlock. I open the unit and I found one of the blades had come off a fan.
When I turned on the unit I could hear the fans, I though that the LCD module was bad. I checked it before I found that it was configured for 240VAC.
I will probably change both fans.
Best regards,
Jay_Diddy_B
« Reply #4 on: September 23, 2021, 12:33:51 am »
Hi group,
I changed both fans in the 6050A electronic load mainframe. The fan is described as rectangular/rounded 172mm x 150mm and 38mm thickness.
I selected NMB part number 5915PC-12T-B30-S00 available from Digikey P13606-ND
The replacement fan is a perfect fit and works great.
Regards,
Jay_Diddy_B
Offline Jwalling
  • This is work?
« Reply #5 on: October 25, 2021, 09:48:38 pm »
Need any loads for it?
https://www.ebay.com/itm/154669190507?
Great price... No affiliation.
Jay
