Author Topic: Datron 1062 Repair Series  (Read 1105 times)
Offline TheDefpomTopic starter
  • YouTuber Nerd - I Fix Stuff
    • The Defpom's Channel
« on: May 21, 2020, 03:07:35 am »
Hi all
I have picked up a couple of Datron units, this is the first video about the repairs.
Datron 1062 Autocal Multimeter Repair Part 1
« Last Edit: May 29, 2020, 05:45:08 am by TheDefpom »
Cheers Scott
The following users thanked this post: croma641, chriva, CalMachine
Re: Datron 1062 Repair Series
« Reply #1 on: May 29, 2020, 05:45:53 am »
Datron 1062 Autocal Multimeter Repair Part 2...
Cheers Scott
The following users thanked this post: chriva
Offline odium
« Reply #2 on: May 29, 2020, 07:06:08 am »
nice guessing work :)
will you flash eeproms with compatible firmware versions ?
cheers !
« Reply #3 on: May 29, 2020, 07:10:12 am »
I have ordered some TMS2532 from China, once those arrive I will burn them with the 1071 firmware and give it a go to see if I can get 7.5 digits out of it, failing that I have downloaded the 1062 firmware set that someone posted on the forum which has the same part numbers as the EPROMs on the digital board, so I should be able to replace the GPIB EPROM.
Cheers Scott
« Reply #4 on: June 30, 2020, 01:09:41 am »
Part 3 (I forgot to update this thread!)
Cheers Scott
The following users thanked this post: syau
« Reply #5 on: July 06, 2020, 12:04:17 am »
Part 4:
Cheers Scott
« Reply #6 on: July 18, 2020, 04:10:50 am »
Part 5:
Cheers Scott
« Reply #7 on: July 18, 2020, 04:13:17 am »
Part 6:
Cheers Scott
