i would say you have chances it work, if the 1st pc has/had an intel chipset and the mobo scope has an intel chipset,
same for amd chipsets from one to another, not amd to intel
for sure it will need drivers, the main one is the intel inf chipset drivers, this one goes first ... you have good chance to start it ...
but no offence i do question some of the choices or decisions on how you try to start your rig .... remove all the scope cards and focus on the pc side, i do have doubts on what peripherals this mobo can accept, mostly the ssd technologies involved
sadly i dont have this scope but i would have started a new, fresh install, maybe a new motherboard, but i would have done psu checks, capacitor checks etc ...
no offence once again, but you're trying too many things at the same time
you need to find old ide drives to start the scope, and to recover the drive, it's an ide 44 pins, many adapters / docks / usb to 40-44 pins ide can be used ...
you do battles with oldies as i did on a TEK 7404
took me 2 weeks just to find floppies, tons of cd-roms, some 2.5" drives etc ... originals cd's (not engraved, they where rejected) .... usb and ide interfaces, and i have a few ... but i succeeded, it was a pain in the b #%$#
