Hello everyone.
I got this Geneva XL sound system for free, on the amplifier there is some faulty components, I can't find them anywhere, would be helpful to find out what they are.
On the circuitboard they are marked by Q[and a number] so that means that they are transistors. Looks like it's 8 pin MSOP package(but without the pins) (or are they 4pin with the pins going all the way through? The one's that look healty are OL one way and about 2.7 Vdc the other way.
There are two types, one marked 7414 and the other 7415. The conduct in the opposite way. But I can't find new ones by searching for the writing on the component, can anybody help?
It looks like an S and a Delta symbol also.
The size is 3 mm x 3 mm.
(The R047 resistor is burnt as you can see)
