Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
how do you troubleshoot an Ic(ssc9522s) with a multimeter?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: how do you troubleshoot an Ic(ssc9522s) with a multimeter? (Read 303 times)
Jekgbg
Contributor
Country:
on:
August 11, 2024, 08:09:03 am »
Hi
how to trobleshooting this IC (ssc9522s)
with a multimeter ?
https://acrobat.adobe.com/id/urn:aaid:sc:EU:096f04f8-816f-4fb2-a845-cccec1af9efd
Logged
indeterminate
Regular Contributor
Country:
Re: how do you troubleshoot an Ic(ssc9522s) with a multimeter?
Reply #1 on:
August 11, 2024, 10:07:06 am »
1 get a copy of the data sheet
2 se if pin 2 is being supplied the correct voltage
3 se if pin 8 is supplying your gate drive voltage
4 se if pin 1 has ac voltage on it
make shore there are no external shutdown signals present
Logged
fzabkar
Super Contributor
Country:
Reply #2 on:
August 11, 2024, 04:16:32 pm »
Datasheet:
https://www.semicon.sanken-ele.co.jp/sk_content/ssc9522s_ds_en.pdf
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
