Hello all,
I recently acquired an HP 8559A and instead of the HP 182T display, it was supposed to have I received an HP 180C display. I can't get the display to show a proper trace (I only get a dot or a small vertical line) I've used an oscilloscope to verify that the 35MHz cal output is working (nice clean sine wave) so I know that wasn't the issue.
If someone could advise me as to what I should check next or could direct me to somewhere I could acquire a better display I would appreciate it.
UPDATE: After further research and testing I now believe the issue is with the sweep generator. If I probe the sweep generator output I do not get a signal, but if I manually sweep I see the signal change.
