Q1 looks more like an LDO linear regulator than a BJT or MOSFET, otherwise I can't understand the purpose of C28.
It's a 3.3V regulator rather than 3.0V. I don't know whether that's OK, or whether it affects the calibration.
HelloI had similar situation.Here is my topic https://eevblog.com/forum/repair/voltcraft-vc890-big-current-consumption-180ma/Well regulator is used to supply g230f128 and its 3.3V regulator.If its dead it probably damaged controller as it was in my case, after replacement current consumption was like 180mA and it drain battery in like one hour which made multimeter useless.
