Author Topic: How to repair a USB flash drive  (Read 1425 times)
Offline flasonsmtsTopic starter
  • SMT Reflow oven wave soldering machine factory
    • China SMT reflow oven wave soldering machine factory
« on: July 24, 2018, 06:30:13 am »
Most people has a USB flash drive in hand, and used it frequently in daily office work, And they will meet many problems when using the USB flash drive, But how to fix the USB flash drive when it meet problem, the USB flash drive need the software to repair, you can download the software from the following website and repair you USB flash drive:
http://www.flason.com/download
SMT reflow oven wave soldering machine pick and place machine SMT assembly line https://www.flason-smt.com/
Offline borghese
  • Country: si
Re: How to repair a USB flash drive
« Reply #1 on: July 24, 2018, 06:49:41 am »
You do not specify which problems can be repaired by software; definitely not problems due to faulty hardware.
Cheers
Borghese
Online tooki
« Reply #2 on: July 24, 2018, 07:16:50 am »
As if they fail often (in hardware) anyway... if anything, flash drives have proven to be remarkably resilient.
Offline HB9EVI
« Reply #3 on: July 24, 2018, 09:54:38 am »
if you were familiar the production of flash memory, you would know, that only the junk quality flash chips end up in sticks; first grade chips in sticks you maybe find in expensive high density brand sticks, but not in the department store grade sticks for 5 bucks
Online tooki
« Reply #4 on: July 24, 2018, 04:37:10 pm »
And even those have proven to be quite resilient.
Offline HB9EVI
« Reply #5 on: July 24, 2018, 05:43:42 pm »
then I should throw out the car radio; supposedly only reading the sticks, I already had to throw the third
Online tooki
« Reply #6 on: July 24, 2018, 09:41:12 pm »
Really?!? My oldest flash drive is from around 2001 and I’ve never had one fail, ever.
