Author Topic: Tektronix TDS744A trigger level encoder replacement  (Read 397 times)
Offline the_fpga_stigTopic starter
« on: September 07, 2022, 03:26:58 pm »
I recently acquired a TDS744A in very good condition and recently calibrated.
The only problem is a broken trigger level encoder (probably knocked by someone).
I want to replace the encoder, but I can't find the part number of it. I also don't want to disassemble the broken one because it still works (a royal pain, but works).
Does anyone knows where I can find the part number? The service manual only lists the entire front panel assembly.
Cheers!
