hey all
i have a fluke 114 where the bottom "leg" of the number display is missing
i initially thought that rubber connector thing between the circuitboard and lcd was dirty, but it turns out the edge of the lcd glass got chipped and it's broken one of the connections
any suggestions on what i might do to fix it?
I've cleaned out the shards of glass hoping it was them interfering, but not such luck. I think if i can somehow bridge the connection it should start working ok, but i dont want to jam metal in there as its glass
