Ok, so I've spent some time trying to understand where the problem might be (on top of my very limited knowledge) and here what I find.
When I start the scope, for a fraction of a second I see a trace (more frequent if I have the beam finder pushed). Does this mean the CRT is still working ?
Once the scope is working, if I push the beam finder I see nothing.
I was then trying to see if there where some signal in the defl plates and I found that I do have on both horizontal and vertical.
![](https://lh3.googleusercontent.com/vHUxv9iY0yMvCAuCIRO0sC9406M-ZG4ejF29fL9yMAgipxE-xVmCEwy_Oygj8y3YSRgweOMHII7oR-3_2PwXMSGuJjGWwZxs8y8rura7_UjJ212kFEVdkbhjvn638Tq4Hyba82JiZdNPNM-AdjuYGUKuTLftUq5kDA6UkBC2LeCQd_6DWliFcX1700OpkD4oRfFNqp7H8SDpG1vyRo0wZ0sH8dY1Qr6uIaKIMXl_RjBWYc9m6N4AvtkWbSK4guSWeMkrNHKSsjdZhYshtMr8ddPMlzsPAYLK1ZWdbdATfUIV1d05E54fC80rkGvuJw29BP4Yo5KB9m0hlui1lBH-KJN8NsQjJOCWtgoyrgxODzJgy8g4PDKtLwm99RtMe7jd3aDAV4bf1W4IqFoJ5HFjfP9pHP-MEVW17c59M6NVWWMSaYgLyAD5Vh3cWvJvIQq_C2RpCWIipWCjlrzU0b8HbUo46Q27DXnIeq69F4lixRYXPuT4EEMybyD7hcB9uyVX1H56g-g4azTbcjO17KkDbzVJGFDw1niaMMs8Tb8gJrTPXyUHitvpxPogZriEnEM_UNJVrJftTjbi4SR_nq5am9ZKoiFUIUr2pGdCV_1DjTQbkBKGxLyFWpG8EnxRgXeq-xvbaz4zeGAHt0tSkLbSaQttaI2-emxjLLufYdO9RTJmzjUKs4YvKSilLA=w936-h944-no)
I see also that on the ASTIG I do have some signal as well, but still no single sign of trace... to be honest, I do have much knowledge to understand if even I'm going in the right direction.. should I be seeing anything ? or this can simply mean the problem is someplace else ?
PS: according to the service manual, the horizontal signal should be between +25v and +63v from the wave forms but I no longer have an oscilloscope to test it ... if so, getting 7.3v only on point 9 means something is wrong already ??
Thank in advance for the inputs.
