Hello
I have a defective Philips 55pos9002 Ambilight here. It won't turn on.
I was wondering if anyone else has had the same issue, and how did you manage to fix it.
What happens:
When I plug the power cord in, without even touching the remote control, the
led light starts blinking extremely fast.
Using the remote control doesn't turn the TV on. Actually nothing happens.
I counted the led blinking lights (by shooting a video on slow motion, otherwise it's so fast that it's simply impossible to count) - There are two sequences: 4 initial blinks, followed by a short pause, followed by 41 blinks.
- I've attached the video as a zip file with this post, you can check it out.
I looked up the Service Manual for this TV, in order to find out what this means, but I can't seem to figure it out.
There's apparently two "Layers" - Layer 1, and Layer 2 - so I'm assuming the first sequence of the led blinking corresponds to Layer 1 error codes, while the second part of the led blinking corresponds to the Layer 2 error codes.
However, if that is correct ,there's a match for the first sequence of "4" in Layer 1, but there isn't even an error code for "41" on Layer 2.
The screenshots of the manual are attached below:
The Service Manual can be downloaded from here if anyone is interested: ttps://www.download.p4c.philips.com/files/5/55pos9002_12/55pos9002_12_dfu_eng.pdf
Would appreciate any help.
Cheers
