Author Topic: Needed NVSRAM Dump of TDS640 or/and TDS600 field adjust software [SOLVED]  (Read 914 times)
Offline madaoTopic starter
Hello people.
I have repaired  TDS640,of course capacitor plague.
But NVSRAM  is corrupt  und i am needed dump  of functional TDS640.
Do exist  TDS600 field adjust software?
Thanks.
Matt
« Last Edit: November 12, 2019, 04:40:50 am by madao »
Re: Needed TDS600 field adjust software
« Reply #1 on: November 09, 2019, 08:04:07 am »
I have getting NVSRAM Dump of TDS640.
Greetings
matt
Offline rf+tech
  • Real radios are olive drab
Re: Needed NVSRAM Dump of TDS640 or/and TDS600 field adjust software
« Reply #2 on: November 12, 2019, 02:52:57 am »
Hello madaeo,
Attached below is TDS600A.ADJ Field Adjustment Software. To add support for TDS640 (plain, no letter) to TDS600A.ADJ after installation:
  Open directory TDS600A.ADJ
  Edit DUTLIST. There are three entries, TDS620A, TDS640A and TDS644A
  Add TDS640 below the last entry, save and close file DUTLIST.
  It is necessary to make a copy of file Tds640a.con, and name the copy Tds640.con
  Also, make a copy of file Tds640a.idx, and name the copy Tds640.idx
It is not necessary to edit either file copy. With these steps, I have successfully calibrated a TDS640 on the first attempt.
RF+ Tech
RT-1133 AN/PRC-70  *  RT-794 AN/PRC-74  *  RT-841 AN/PRC-77  *  RT-524 AN/VRC-12  *  RT-834 AN/GRC-106  *  RT-F100
The following users thanked this post: madao
« Reply #3 on: November 12, 2019, 04:38:48 am »
Great !   Thanks.
It is really simpel !
Regards
Matt
