For the A9 board, Check if F2, C2 [500uF], is OK,
then if fault is not found,
measure Q1, Q1, Q2 BCE voltages as last resort.
Edit: this kind of intermittent you should also careful for cold joints, contacts etc...
EDIT: [PARTICULARLY R12 WIPER CONTACT - CONTACT CLEAN, CHECK OR REPLACE]
